Tow bar Twin Electric Sockets
Majanor
Unread post by Majanor »
Hi, looking to add proper tow bar electrics to C5 Estate
This is on Ebay
New Genuine Citroen C5 Break Estate 7+7 Twin Socket Towbar Wiring Loom 9428.75
Twin socket installation is perfect for me but is this the correct Harness etc
Interface/Fuse box Is Part 9688EL the one I need ?
Have read posts re. !3 pin installation
Any other parts reqd ?
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks, Norman
x 6950
Re: Tow bar Twin Electric Sockets
The loom is incorrect for your vehicle (9428.75) but the Trailer fuse box is ok (9688EL).
9428F7 is the correct listed 13 channel towbar harness for electrical supply of a trailer on this specific vehicle. Compatible with towbars, part nos. 9427CV, 9427CW, 9427CX, 9427CY.
Majanor
Thanks Marc, did see that loom for 13 pin socket. Caravan is twin plugs one grey 12S, one black 12N. It would be a right Pain to change it to 13 pin, hence hoping that the twin socket loom would be the answer.
Have to stick with aftermarket kit removed from my C 5 saloon
Cheers
x 1955
Unread post by Paul-R »
You can get adaptors from 13 pin to 7 pin and vice versa.
Majanor
Adaptor may be way to go, thank you
x 1061
Unread post by wheeler »
If i was fitting a towbar to my car now i would only ever fit a 13 pin socket, even if i was only using it for lighting. The 13 pin plugs are far superior to the old 7 pin sockets. I would also change any trailers i had to match. As said there are adapter available to convert either way
Sloppysod
x 407
Unread post by Sloppysod »
Majanor wrote: 25 Jun 2024, 19:01Norman
If you can track down the correct harness I would… the genuine Citroën harness also alters the way both the ABS and traction control ECU's operate - noticeably, giving a safer rig/outfit.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
daviemck2006
x 485
Unread post by daviemck2006 »
I would put on the 13pin socket correct for the car. Then buy a 13pin to 2x7pin adapter. That's what I have on my daily Skoda, and that's what's on my recently bought dispatch van. The adapters are cheap on ebay. My caravan has twin 7 pin, skip run trailer has 1 7pin, and a hired car trailer had 1 x 13 pin plug. All worked properly with the adapter.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
