Ds3 injector coding
Ds3owner93
Ds3 injector coding
Hi guys, just replaced 3 injectors on my ds3 as they came up as faulty and had the injector tick, after replacing the tick has gone away but I'm having a nightmare with the coding, and i have the EML light flashing so I cannot do the rapid learning code P062B comes up, I made sure when coding that the part number I was fitting was correct, now when I'm trying to code the car it is automatically changing the codes not to what I'm putting in then tells me to drive get the car to 2600 rpm and let it settle to 1500 without touching the pedals but I cannot do this as it won't do the rapid learning with the eml light on
dylan26__
- x 22
Re: Ds3 injector coding
Hopefully you sorted this by now but if not. I have to assume it's a 1.6hdi diesel injector. I've replaced two of these. The coding must be done via OBD, make sure you put the right code in from the top of the injector. It should be done with the ignition on, engine off. I've not had to do any learning once the code was put in as the car will automatically do thatDs3owner93 wrote: 23 Jun 2024, 18:54 Hi guys, just replaced 3 injectors on my ds3 as they came up as faulty and had the injector tick, after replacing the tick has gone away but I'm having a nightmare with the coding, and i have the EML light flashing so I cannot do the rapid learning code P062B comes up, I made sure when coding that the part number I was fitting was correct, now when I'm trying to code the car it is automatically changing the codes not to what I'm putting in then tells me to drive get the car to 2600 rpm and let it settle to 1500 without touching the pedals but I cannot do this as it won't do the rapid learning with the eml light on
