Ds5 check engine repair needed
JamieLeeWV
Unread post by JamieLeeWV »
Hi guys. Had my ds5 1.6 auto serviced by Halfords last week (I know [-X ) so not sure if related.
Quick history it currently has 94k on the clock. I brought it last year with 88k on the clock from a reputable dealer. It came with a tonne of paperwork with all the work it's had done to it (timing belt and water pump changed at 67k, new battery etc) so I can see it's a car that's been well looked after.
Not been an issue since I had it last year, however after turning the engine on this morning I had a message saying 'engine fault repair needed' and the service light came on. There seemed to be a large squeaking sound from under the bonnet, turned the engine off turned it back on again and the message and service light didn't reappear.
Took it for a quick spin round the block and it seemed to drive fine no loss of power etc.
I've been out in it since approx 20 min drive to the shops and the message hasn't reappeared or anything and driving fine, could this have just been an error on startup? Do these things happen? Or is it something more serious potentially?
I have a friend coming round to plug in a diagnostic tomorrow so I'm hoping its nothing serious seeing as it hasn't come on since?
Anyone else have any experience of this? Thanks
x 6955
Re: Ds5 check engine repair needed
First avoid Halfrauds, they really don't have the same training.
It may be a coincidence, of course, but keep an eye. Sometimes it may be emissions related, but have it scanned (preferably with Lexia / Diagbox) and pop any codes up here with your VIN.
PaulC5
x 574
Unread post by PaulC5 »
Until your diagnostic check I would have a quick look over the things Halfords have done including checking the oil level. If the engine management light did not come on a basic code reader might not come up with anything.
JamieLeeWV
PaulC5 wrote: 23 Jun 2024, 11:48 Until your diagnostic check I would have a quick look over the things Halfords have done including checking the oil level. If the engine management light did not come on a basic code reader might not come up with anything.
Yeah I'll have a look at the oil levels after work today and get back to you. I'm hoping it is just an error in the system as it came on once then didn't reappear after restarting the engine
JamieLeeWV
GiveMeABreak wrote: 22 Jun 2024, 17:12 First avoid Halfrauds, they really don't have the same training.
I know, no idea why I went there tbh 😂.
I will report back any findings today have a friend coming round this evening to plug in.
JamieLeeWV
Ok so my friend plugged in box and got one code,
U0103 module A.
My vin is VF7**************[VIN obfuscated, can be read by forum staff]
the light saying engine repair needed hasn't come on again since yesterday and it only came on once, so not sure if it's serious or not? Or something to keep an eye on?
x 6955
Fault Code: U0103
Description of Fault: Intersystem CAN network: Absence of communication with the automatic gearbox or piloted manual gearbox. Faults in communication between ECUs on the CAN. At least one of the following conditions must be fulfilled:
- Engine running
- Switching on of the ignition
Conditions for Fault to clear:
  • Driving for 5 minutes
Downgrade Modes whilst Fault is active:
  • Irreversible deactivation of the vehicle cruise control
  • Sending of the information "torque uncertain" on the CAN network
  • Switching on of the warning lamp and/or warning message: Warning lamp MIL
Symptoms:
  • Engine hesitating, cutting out
  • Lack of power
  • Starting problem
Suspect Areas:
  • Engine ECU
  • Intersystem CAN network
PaulC5
x 574
You have not reported any of the symptoms listed for this code, it could be an old one that has never been deleted. If your code reader does freeze frame data make a note of it and also if it gives how many miles the car has done since the code. You could then delete it and see if it comes back.
It is always worth checking the battery voltage and have a listen around the alternator belt area in case the drive belt / its tensioner are on their way out.
