Injector fault
JantheNan
New User
Injector fault
Unread post by JantheNan »
Hi, as a new member please don't judge my ignorance. I have a C4 Grand Picasso 1.6TD semi automatic on a 61 plate, I only have 87500 miles on the clock. My problem is this on 8th June I had an injector 3 fault. The RAC mechanic came to my home and replaced the injector. However uit still diagnosed an injector 3 problem. May be a faulty injector I hear you say. Two days later RAC return with a new injector. Three days later the same fault occurs. Again RAC attend and replace the injector. She now sits in a garage whilst they try and locate the Faulty Injector 3 problem. Does anyone have any ideas as to why this is going on? They have check the cylinderhead pressure and the wiring, but have still got the same problem. Please help.
x 1487
Re: Injector fault
Citroen number their injectors from the flywheel not the timing belt like most other makers. Have they changed the right injector??
