Citroen Nemo coolant
Trasdtaw21
Unread post by Trasdtaw21 »
I have air in my cooling system. I dont know who to get the air out. Has someone an idea? I took out the coolant sensor and saw that there is not enough coolant. I refilled but somehow there is still air inside. Dont know where the coolant drain is.
x 6945
Re: Citroen Nemo coolant
There is a specific procedure that has to be followed to bleed the cooling system correctly (degassing), and will usually need some tools to do it properly. Best to get it done by a professional if you don't have experience, or you'll end up with problems.
