absence of communication with ecu
lanlee666
my car, peugeot 207 1.6 petrol. crank not start problem. I believe there is no power to the ecu. I notice the is no power at the f15/30a fuse also. maybe relate to ecu. what is possible sensor that cause the ecu no power. Thanks for any help
darbuck
- x 291
- x 1050
Re: absence of communication with ecu
Can you get comms/does the engine start if you give the fuse 12v.
Really need a wiring diagram to investigate further.
lanlee666
the fuse itself no power.
lanlee666
The engine still can crank but still no comm with ecu when I jump 12v to the fuse.wheeler wrote: 15 Jun 2024, 11:46 Can you get comms/does the engine start if you give the fuse 12v.
darbuck
- x 291
Ok sorry misunderstood your question there must be either a break in the cabling or possibly the ECU. Have you checked the wiring from the OBD port to the fuse box for continuity. Ideally you need a wiring diagram for this. If you don't have one perhaps ask In a new topic. It's hard to diagnose without knowing your wiring is good.
Darren
lanlee666
thanks for the reply. I'm still looking for wiring diagram for this car on the net.darbuck wrote: 16 Jun 2024, 08:44 Ok sorry misunderstood your question there must be either a break in the cabling or possibly the ECU. Have you checked the wiring from the OBD port to the fuse box for continuity. Ideally you need a wiring diagram for this. If you don't have one perhaps ask In a new topic. It's hard to diagnose without knowing your wiring is good.
