laguna 3 1.5 dci can fault on electronic hand brake
Dan1el
Unread post by Dan1el »
Hi driving along and get check vehicle warning, the electronic brake has complained about the 2 switches on clutch and potentiometer, however on other systems and with multi meter I can find no problems with them.
I'm getting DF068 invalid multiplex codes from UPC in glove box to Electronic Hand Brake module. I have checked stripped and cleaned connections on UPC and electronic hand brake and checked fuses.
I have checked the plug under rear bench and the parking brake has no symptoms of moisture.
currently have a Autel 808 BT to scan the car
thank you
Dan1el
Re: laguna 3 1.5 dci can fault on electronic hand brake
Fixed.
You have to love Renaults for poor diagnostic codes.
Big thanks to Russian site for wiring diagrams for free.
Hope everyone has a wonderful father's day
posicar
New User
Unread post by posicar »
Hi Dan1el,
I think I have a similar problem. Could you let me know the solution you found?
Thank you
