Hi folks .
I've a check engine light with fault code p0421 pre catalyslzer detected absent . Can't seem to find any info on going relating to this . ? Thanks
Berlingo P0421
rafal85
Re: Fault codes
I fixed egr errors by replaced egr, overboost errors were solved by turbo replacement.
- x 1489
Re: Berlingo P0421
Split this off into its own topic. Can you confirm what engine you've got Jonathan, and put the VIN up (it will auto hide)?
Jonathan coughlan
Re: Berlingo P0421
1.6 diesel..
- x 6945
Re: Berlingo P0421
My information indicates if the engine diagnostic warning lamp comes on with this fault (90421) present, then an Engine Management Software Update is required.
Jonathan coughlan
Re: Berlingo P0421
Thanks for your quick reply .Is it safe to drive until I get the update
- x 6945
Re: Berlingo P0421
Yes, it's just mentioned in a bulletin I have, so thought it worth a mention, of course for all I know, you may already have had the update, but a dealer could check. Of course they'll probably charge you the diagnostic time, but that should include the update if necessary.
- x 1489
Re: Berlingo P0421
Did you fix the previous issue with the dosing pump? Given this has done over 100k miles seems unlikely it's suddenly developed a software issue. We had a thread recently about temp sensors on the pre cat, that seems the only sensors, what does the live data say about the temperatures?
- x 6945
Re: Berlingo P0421
The update was 2020, so always possible they have found an issue and provided a fix.
Jonathan coughlan
Re: Berlingo P0421
I couldn't find someone to sort the eyols pump so got the whole lot mapped out
- x 1489
Re: Berlingo P0421
Ah...that puts a different slant on it. Potentially they have not done it right, and I suspect you may have emissions trouble come MOT (NCT?) time....
Jonathan coughlan
Re: Berlingo P0421
I got it mapped out a few months ago. Went through the nct with flying colours last week but engine light came on the day after the test .my mechanic thinks cause they had the van at full throttle for the emissions test it might off set off the fault and might need to go back and get re mapped .I just couldn't find any info about the fault code with the description on goggle
