Abs traction control
simplecrater
Hi thanks for add been trying to get bottom of abs light on dash so far replaced the wheel speed sensors abs rings in hub and still got light on we are using Autel maxi elite diagnostics but still stumped.we are going to go down road of a replacement abs module.but do they need coding at dealers? Or is it possible with our own diag tool thanks again
- x 6954
Re: Abs traction control
Yes they do if this has ESP.
You haven't provided any fault codes - we really need those to provide further assistance as replacing parts is not solution without knowing the cause. If you have these, then pop them up with your VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
simplecrater
Now sorted with 2 new back wheel sensors and new rings on the hub thanks
