1.6 dci P0488; P0101 - EGR or MAF problem?
casperslonina
New User
Unread post by casperslonina »
Technically the car is not french but engine is renault after all, so please forgive me.
Qashqai 2012 1.6 Dci high mileage (over 200k), first realised there is a problem when car started stuttering slightly on the motorway. Eventually it stalled while driving off in a car park. Error P0488 EGR - throttle position control - range/performance problem. After few tries I managed to turn it on and drove back home. I cleaned existing EGR valve - did not help. I replaced the EGR. Car stuttered again slightly until check engine light appeared with P0101 - MAF/VAF sensor - range/performance problem. No EGR codes anymore, only MAF. What's interesting is that car runs smoothly now with the check engine light on, but cruise control/gear indicator is disabled. I tried to delete the code, but it comes back every time I turn the car on.
I'd be grateful if somebody could help me solve this issue - is MAF worth replacing? or is MAF code reactive to something else?
It seems like EGR works just fine after replacement.
x 1487
Re: 1.6 dci P0488; P0101 - EGR or MAF problem?
What does the live data show? Does the air flow look sensible? Have a good check under the bonnet for a boost leak.
x 1942
Unread post by Paul-R »
You could try cleaning the sensor in the MAF if it's become coated with oil and/or dirt.
MAF cleaning is mentioned in these posts
viewtopic.php?p=800239&hilit=maf+cleaner#p800239
viewtopic.php?p=800048&hilit=maf+cleaner#p800048
viewtopic.php?p=797040&hilit=maf+cleaner#p797040
