Popping Out of Reverse Gear
Peugeot need help 1
Just want to post a question about my 207 jumping out of reverse after a clutch change perfect before for at least two years never a problem before
Reason: I've created a new thread for you as the one you posted in was over 10 years ago.
- x 6955
Re: Popping Out of Reverse Gear
I suspect it has not been fitted properly - probably needs re-checking and making sure it's been properly fitted and adjusted. Some people don't bother using proper alignment / fitting tools and this can happen.
- x 1342
It would also be worth checking that the gear change linkage has been refitted correctly and is allowing full engagement of reverse gear. Maybe something got bent while removing or refitting the gear linkage?
