207 rear discs
PopPops
207 rear discs
Unread post by PopPops »
Hi All,
I hope this hasn’t been asked a million times before. I need to change the rear discs on my wife’s 2010 207 vti as they were an advisory on the last MOT. Are all the rear discs the same, there seem to be so many types listed online that I’m getting a bit confused? I’ll only put good known makes on.
Also, does anybody know the hub nut size, to make sure I’ve got the right socket before removing the dust cap?
Many thanks.
Nigel
x 1496
Re: 207 rear discs
They all appear to be 249mm dia x 9mm thick solid discs. Hub nut is the same as on a 307, which I needed to get a 36mm socket to get off, as my 35mm front hub nut socket wouldn't fit....
PopPops
Re: 207 rear discs
Thank you very much!
Nigel
