Please help I have a Citroen ds5 riddled with problems
Carlos Pena
The car has an error message when I accelerate that says engine oil pressure fault, also out the blue the driver window stopped working and the brakes went stuff on me while driving also the ac makes a knocking noise so I don’t use it help please I live in Antigua and it’s the only ds5 that is on island no mechanic knows what to do
- x 1955
Re: Please help I have a Citroen ds5 riddled with problems
A few more details of the car are needed including what engine fitted.
- x 1481
Do you have access to a diagnostic code reader?
Carlos Pena
I’m not sure if the engine I can find out but do you have any recommendations as well as I will try get a code reader only one that comes to mind is U1213
- x 6950
U1213 is really a generic communication fault with the CAN network and can relate to many different ECUs, so is not really any help without knowing the context in which it appears and under which specific ECU.
Carlos Pena
Where can I buy parts for it that are affordable it needs an oil pressure switch and knock sensor
- x 6950
Well obviously as near to Antigua as possible as you are going to face quite expensive shipping costs for parts. It all depends what you want. Sensors may be provided by other suppliers so may be cheaper to source more locally, but the part number is essential and a branded quality part, as cheap sensors often fail or don't work properly. Oil pressure switches and a knock sensor should be easy to source as they are common, as long as you use the correct part number.
