2010 1.6 hdi 109hp
tersfilozof
2010 1.6 hdi 109hp
Unread post by tersfilozof »
Hi Everyone, i have this short rattling sound when i release gas pedal when idling and i hear it when press and releasing while i'm driving in 1st 2st gear. It comes from turbo or behind turbo. What do you think it can be? it's like vibration. I asked too many mechanics, some said turbo, some said engine or manifold. Please help me out if anyone faced before.
PaulC5
x 698
Re: 2010 1.6 hdi 109hp
Unread post by PaulC5 »
What car is it ? I could not hear anything other than a diesel running.
x 6946
I would of suggested (without first hearing the noise) that it would be an exhaust heat shield, but it doesn't sound as 'tinny' as the noise they can make when loose. :-k
x 1471
Unread post by xantia_v6 »
I think it could be worn turbo bearings allowing one of the impellers to rub on the casing as the pressure changes.
Take off the intake pipe and check whether there is movement in the shaft.
tersfilozof
xantia_v6 wrote: 10 Jun 2024, 11:39 I think it could be worn turbo bearings allowing one of the impellers to rub on the casing as the pressure changes.
Can i do it while car is working?
tersfilozof
GiveMeABreak wrote: 10 Jun 2024, 11:06 I would of suggested (without first hearing the noise) that it would be an exhaust heat shield, but it doesn't sound as 'tinny' as the noise they can make when loose. :-k
I checked it. It doesnt sound like the heat shield.
PaulC5 wrote: 10 Jun 2024, 10:58 What car is it ? I could not hear anything other than a diesel running.
volvo v50 PSA engine.
