MAX USB Drive Size - C5X
This section is for information and posts relating to Audio Head Units, and Navigation Systems
Sloppysod
x 384
Unread post by Sloppysod »
Doe anyone know where I can find out the recommended or maximum size of USB drive for my C5X, I have looked through the user manual :? and yes its says I can store Music in various formats, but nothing about the recommended drive size!
I can get a Type-C, USB drive in either 16, 32 or 64 GB what would be best? I'm thinking 16 or 32, but I am not sure the car will accept it.
Thanks In advance
Stu
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6953
Re: MAX USB Drive Size - C5X
Hi Stu, well I use a Samsung 64gb USB on my Wave 2 system and that works perfectly, so there shouldn't be any issues there. Plus that's on the spare USB port I made using the secondary port on the back of the head unit, so I have CarPlay on one USB and the 64 Gb drive on the other port in the glovebox - both work without issue both at the same time.
https://www.amazon.co.uk/samsung-flash- ... ers&sr=1-3
Sloppysod
x 384
Re: MAX USB Drive Size - C5X (& Not Recognised Error)
Note for others
So, I bought a 64Gb drive, transferred about 35GB of music over (5 hours+), plugged it into my car and got the error message "USB device not recognised" - #-o
I thought that buying a drive that was windows compatible I would not have had any problems.........
However, the drive had arrived in exFat file system and NOT the Fat32 I had expected. (exFat file system suits Windows and Mac OS X operating systems, and allows larger files of 4GB+)
And......The basic drive formatting utility in windows explorer would not allow me to change from exFat to Fat32 as the only options were either exFat or NTFS!
So, using a piece of freeware (AOMEI Partition Assistant ) I found I changed the file system from exFat to Fat32 all was okay. =D>
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6953
Yes - all in the manual that Stu :-D Only FAT32 currently supported.
There are plenty of utilities that will do this and even Windows will allow you to do it if you know how using the command prompt.
