So I plugged my new-to-me C5 X7 (2009 138 HDI FAP) into diagbox for the first time and found a few fault codes. A few were related to high fuel pressure at 3850 rpm in 4th (auto) but I decided to clear everything as I had no idea when they occurred so decided to start with a clean slate. However, a couple of them were persistent and I wonder if anyone has any advice
BSI code F5FF Unexpected re-initialisation fault coming from the BSI - Local - Not characterised
Electronically Managed Suspension code U2005 Triggering (vehicle speed receipt anomaly - Disant - Permanent fault
Apart from those, everything else seems ok but I will see if the fuel pressure faults re-occur over the next week
Thanks for any pointers
C5 X7 fault codes - can anyone advise plz?
steveclv
- x 40
- x 6955
Re: C5 X7 fault codes - can anyone advise plz?
Ignore all those, U2005 when appearing on a Global Test without other issues is a ghost fault, triggered by the interrogation of the Suspension ECU when the vehicle is stationary.
The other F5FF one is no concern, it's a common BSI one that happens every now and again.
steveclv
- x 40
I'm just wondering whether the battery needs changing as I have read that when cranking, if the voltage drops too low then it can cause an unscheduled reset of the BSI. Battery seems to be about 6 years old based on the service receipts so maybe worth doing anyway.
The other faults on the fuel system - mainly P0088 High fuel pressure based on my research elsewehere, where people have spent thousands replacing sensors, fuel rails, injectors and fuel pumps, might be just down to a fuel filter - weird I know but something to do with fuel starvation at WOT (I was at 3850 rpm, D4 and WOT) which when the throttle is released causes a momentary high fuel pressure condition. The filter was last changed 2 years ago so I'lll give it a try this weekend.
- x 6955
Pop your VIN up when you get a chance so I can relate this other new code you have to the correct Engine ECU. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
steveclv
- x 40
Thanks - here you go
- x 6955
It's also important to note the context of this fault and whether it appears as a result of the engine stalling or if it has difficulty maintaining idling speed, such as hesitation or not, because the context can help fine tune the fault. In the case of the the engine cutting out after starting for example, it's likely to be the fuel temperature sensor that is the culprit - or it's electrical connection.
As for the specific fault code in isolation:
| Fault Code: | P0088 |
| Description of Fault: | High pressure fuel regulation: The measured rail pressure is too high in relation to the set point. Description of the diagnostics The ECU detects a difference of 180 bars to 250 bars for 3 to 6 seconds between the rail pressure set point and the measured rail pressure. |
| Conditions for Fault to clear: | Driving for 5 minutes with several full load accelerations for 10 seconds |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
steveclv
- x 40
Assuming that it occurred when I was overtaking, then it exhibited no hesitation or limp mode like activity - just the warning message and the engine check light that extinguished the next time I started the car. It idles perfectly and runs just fine at normal speeds and accelerations - I don't think I have used WOT since that particular error.
However, I don't know if that was the situation that generated that error as the fault codes are not date stamped - I've attached a print out of the exact code results (I had to zip it up as pdf isn't a valid file type for the forum apparently)
Many thanks
Many thanks
- Attachments
[The extension zip has been deactivated and can no longer be displayed.]
- x 6955
Here are the others - I've left out the Cruise Control fault (P1671) as that's nothing specific and will be deactivated whenever there is a fault with the engine management system.
| Fault Code: | P1166 |
| Description of Fault: | High pressure fuel regulation: Measured rail pressure higher than the maximum pressure. Description of the diagnostics: Pressure of the fuel high pressure common injection rail measured higher than the maximum pressure of 1800 bars for 6 seconds. |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0112 |
| Description of Fault: | Intake air temperature signal (Air flow meter): Short circuit to earth; Value too low. Description of the diagnostics The voltage of the inlet air temperature sensor signal is lower than 98 millivolts corresponding to a temperature of 130°C for more than 500 milliseconds. |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0215 |
| Description of Fault: | Supply relay control: Short circuit to earth or short circuit to positive or open circuit. Main relay remains stuck during the phase in which the engine management ECU becomes dormant. |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
steveclv
- x 40
You see that's the problem - if you read the 'symptoms' then it implies that the car is undriveable but as I said earlier, apart from the error messages, the car behaved perfectly. I am suspecting that it might have been a fault that was already there and the error message is unrelated - or maybe it's the battery as they all suggest 'electrical harness'. I think I need to pull the fusebox/BSI off at some point to replace the gearbox mount so that will give me a chance to clean everything.
- x 6955
Yes, always clear faults first if this is a new (to you) car, then go for a drive and re-read the vehicle.
These may be original faults that weren't cleared down. Only deal with them if they are re-triggered.
