engine keeps on revving up and down when idling and revs up when changing gear,fault is intermittant only pattern i can see is it seems not to do it when the engine is cold .i,ve had it coded but nothing so far changed throttle/pedal senzore(£225).For a months back and forth from main dealer,traveling on saturday need solution quick pleaseeeeee.[?]
Thank you all in advance for right replay.
I am buying a round when i get back! [:)]
idling and K light on Xantia 2.1td
Stuart McB
