C4 GP -07 No connection to ECU / TCU & error U1313
GrandPicasso07
Unread post by GrandPicasso07 »
My -07 Grand Picasso (petrol) gives "faulty" messages from ABS, ESP, Handbrake, Gearbox etc., seems to be quite common problem.
Tried to get error codes with simple OBD reader & Android App, gives just U1313 (stays after erase) and U0404 (can be reseted, for a short time). I drove to local car parts store that has generic bigger, automated OBD / diagnostic reader. It could not connect to ECU / ABS unit. Have not yet found any local guys with Lexia. (I'm a fresh Citroen owner so I don't have my own Lexia, yet.)
I guess the problem might be the wiring somewhere? I have checked now;
- fuses & connections above battery (battery was replaced two years ago, should be ok)
- fuses in fuse box next to battery
- first glimpse with the cable punch near battery & fuse box, no corroded/broken cables sighted yet
Before checking brake light switch and cables around every tire, is it possible that those locations could prevent the connection to control units?
I could check connections to ABS unit connector, if I could find which pins are related with 12V and ground.
x 1459
Re: C4 GP -07 No connection to ECU / TCU & error U1313
Unread post by xantia_v6 »
Maybe you have seen viewtopic.php?t=68753 It is not definitive, but somewhere to start.
GrandPicasso07
Not sure if ZeroSix got his/her problem solved on that thread. The linked video I saw earlier.
I wonder, can faulty ABS sensor create this kind of problem? Or would diagnostic tools just pinpoint "faulty ABS sensor rear left " etc.?
GrandPicasso07
What's Your opinion, is the red-white wiring OK? Could it be just dirt or color from the cars body?
GrandPicasso07
Tested also the brake light switch, seems to be working (one pair of pins gives signal to multimeter and the other pair gives when pushing the sensor).
