I'm in colombia with a Argentine build 307 4 door. Has a 2.0 hdi 8 valve. No DEF. Intercooler. Assume it's a 110. Has 170 000km. And I want to proactively replace the SCV or Suction Control Valve. Fuel pressure regulator on pump. It has the bosch pump and injectors. I know on my nissan xtrail 2.2 diesel I needed to force relearn the ecu after replacing its scv using a variation of key on.. fuel pedal to the floor 10x. Etc etc. But I can't find any procedure to force relearn on the Peugeot PSAs. Is it possible without dealer scan tool? Is it necessary?(I rebuilt my bosch injectors and computer simply relearned new trim levels while driving). Will a BSA reset put car into relearn mode? I want to know before I do it, what I need to do to complete the job.
Thx Viktor
