Note it happened after 2000miles after clutch any help pls
C3 16hdi broken wire too the boost control
Mananakev
Hi had car checked I knew boost control was faulty so changed it with it connected went into safe mode max3000rpm disconnect plug re set and would rev ok but black smoke ill replace the two wires but were to they go to
