Radar monitoring fault
gigabi
Unread post by gigabi »
Hi folks, just got myself a 2020, 2008; one week later 'radar monitoring fault' flashes up on the display.
Peugeot wanted £120 just to look at it, and my two local Peugeot specialist garages cannot help.
So, does anyone have any advice/info that may be helpful? Is this just a hot swap part or does it need calibrating?
Look here, if you’re hunting for top-shelf cuckold p**n sites where real men get off watching their ladies getting slammed by other dudes, you’ve nailed the jackpot.
https://cuckoldporn.tv/categories/
https://cuckoldporn.fun/categories/swingers/
https://realcuckoldporn.net/
x 6947
Re: Radar monitoring fault
Unfortunately the front radar system is incorporated into the grill area. They are very sensitive to any knocks and if this is the case and it is slightly out of alignment then it needs a professional ADAS Centre equipped to calibrate the system.
Peugeot will obviously have to charge you diagnostic time which is about right to check what the fault is before they can provide you with a solution. It may well just be a calibration required or it may be another fault, but you need a diagnostic to determine this.
