Just got myself a new Boxer from 2018 with the 2.0 blueHDI engine, max total weight 3.5ton.
Going to start with replacing front discs, pads and ball joints but cant find the right dimensions?
Finding two different "cone sizes" 20.5mm and 24mm.
For the discs there seem to be 280mm x 24/28mm and 300mm x 24/32mm.
Is the only way to find out to dismantle the parts and measure?
Thanks in advance!
Boxer / Relay 2018 - Discs & ball joint dimensions
idinabyxor
PaulC5
- x 697
Re: Boxer / Relay 2018 - Discs & ball joint dimensions
Using your VIN in the parts diagrams should give the correct parts. The best place to post requests for part numbers is here viewtopic.php?t=69962
