C4 Picasso 2016 - Carplay ?
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
FredericB13
Unread post by FredericB13 »
Hello everyone,
I hope you are all well.
I just bought a 2016 Citoën C4 Picasso, 1.6 HDI 120 HP. I am very pleased with this so far.
My only issue is to find a solution to have the Apple CarPlay displayed on at least one of the two screens, using Waze, Spotify, etc.
Is it possible? If so I have not found how to do that, even with an interface.
Thank you for your help.
Frédéric
x 6945
Re: C4 Picasso 2016 - Carplay ?
We'll need to determine what system you have first of all. Your car may be too early for CarPlay. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
FredericB13
Thank you, Marc, for your help.
My VIN is :
I look forward to hearing from you,
Regards
Frédéric
x 6945
Ok, so you have the older SMEG system and that is recorded as without MirrorLink - which was the old connectivity, now not very much supported. So with this info it looks like CarPlay was not available, nor Android Auto, being a May 2016 build. It was the later build from June 2016 that got the later SMEG IV+ system that had CarPlay.
This being the case, there's no upgrade to this system to enable it.
FredericB13
Thank you very much, Marc.
Is it possible to replace my SMEG by a newer version with CarPlay, I could perhaps find on eBay or FaceBook?
If not, is there another possibility?
Moreover, on the 12" screen, is it possible to have the left dial displaying the speed and other car parameters, while the centre and right dials display the SatNav map?
Thank you for your kindness and support.
Regards
Frédéric
x 6945
It's possible, although you may have to replace not only the hidden head unit behind the dashboard, but may need a different touchscreen - I can't say for sure, as well as the coding of the unit to the vehicle and possible BSI programming to ensure features like CarPlay are active.
FredericB13
Thank you again, Marc.
I shall look for an interface. That seems easier.
In regards to the display of the map over two dials on the 12" screen, do you know if that is possible?
Thank you.
Frédéric
x 6945
I don't think it is. Only some later displays are configurable with limited options for how the info is displayed. Your owner's manual should advise as to what you can or can't display. If you don't have the full owner's manual, see my post here on how to download the full manual freely from Citroen here:
Owner's Handbook Link
After following the instructions in the link to select language and model, make sure you use the 01/06/2015 - 19/06/2016 date range for your vehicle manual to ensure you have the correct year. The manuals are based on build date not registration date and I have checked this as the correct manual.
Xaerocool
Unread post by Xaerocool »
Hi there
Hope you're well, i can't seem to work out if the car has carplay, it's a 2016 C4 Picasso Grand...from the below maybe it doesn't have it but could someone confirm for me please? I don't know how.
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks
J.
