SIM card module pinout / 96638354XT
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
Jarek9008
Unread post by Jarek9008 »
Hi, maybe someone of You have wiring diagrams/ pinout description of brown connector from this module?
x 6955
Re: SIM card module pinout / 96638354XT
You need to ber in mind that the X7 can be supplied with and without the services module (similar to independent telematic unit) in which case the whole of the NG4 system is wired differently to incorporate this module if fitted.
Below is the SIM card for the X7 that is conencted to the Services Module.
6 Pin Black Connector:
1: 84A2 : SIM card clock
2: 84A3 : SIM card reader earth
3: 84A6 : SIM card reader supply
4: 84A4 : Unknown
5: 84A5 : Presence of the SIM card reader
6: 84A7 : SIM card reader reset
Jarek9008
My idea is to connect in parallel with this reader instead of the SIM reader in the main unit of the Android radio. Do you think this could be possible?
x 6955
I can't answer that as the unit for the X7 is designed to interface with the NG4 / Services Module equipment and connecting it up to another system may casue undesired results...
Jarek9008
Thank You for Your replay and schemes! :)
Jarek9008
GiveMeABreak wrote: 26 May 2024, 11:13 You need to ber in mind that the X7 can be supplied with and without the services module (similar to independent telematic unit) in which case the whole of the NG4 system is wired differently to incorporate this module if fitted.
4: 84A4 : Unknown
Do You have pinout diagram for this service module (MDS). I'm looking for microphone connection.
