Of the two buttons on my remote key fob thingy, only the one closest to the actual key seems to do anything. This activates the central locking, and upon deactivating the central locking, the indicators flash.
The 'light' on the remote doesn't appear to illuminate, and pressing the second button doesn't appear to have any effect on the cat. I've had both batteries replaced.
Is my key fob knackered, or can I somehow re-tune it to the car or can someone tell me what its for please. ?
Cheers..
Phil
Key question ?
PowerLee
The second button should set the deadlocks if you have them.
To test if you have deadlocks, Lock the car with the key in the door, turn the key towards the rear of the car & hold it there for a few seconds, Central locking should lock & then you should hear the deadlocks setting.
Try locking with the big button & then withing 3 seconds pressing the little button & listen for the deadlocks setting.
Rivendell
Ok.... It seems I have deadlocks [:)] and pressing the other button within 3 seconds of pressing the first button does seem to activate something. Is there any other use for the second button, other than pressing it within 3 seconds of the frst..?
I assume the alarm is activated by pressing the first button and activating the central locking ?
What's the difference between central locking and deadlocking ? I realise this is probably the daftest question opsted today, but some clarity on this would be most helpful.
Cheers
Phil
Cheers
Phil
wrinklet1
pressing the first button nearest to the key locks the car and pressing the second button deadlocks the car AND activates the alarm.
Pressing the first button then ulockes the car and truns off the alarm.
The alarm siren silencer is under the bonnet near the passenger door on the window vallance near the screen. put in the ignition key and turn will deactivate or activate the siren.
Regards
Paul
Regards
Paul
PowerLee
Rivendell
I've just looked under the bonnet, as suggested, and there is a key switch there. As my next door nieghbour has small children, I'll wait till tomorrow to try activating the siren and stuff.
It's amazing how much you can get to know by asking the right questions in the right places [:D]
Thanks guys, I'll come back to you with more questions should tomorrows experiments prove to be unsuccessful, or raise new issues for me.
Cheers,
Phil
Cheers,
Phil
np
The central locking locks the car as normal.
Deadlocks= If a thieving little bugger smashes a window and trys to unlock the door from the inside,the locking catch would move as normal,but the doors would not open.This is deadlocking.You cant open the door from the inside.
Try it.Sit in the car,lock it and deadlock with the fob,you`ll see what i mean.
Rivendell
I now understand the principals behind the dealocking issue, thanks guys.
My deadlocking only seems to work during the 3 seconds after activating the central locking. Is this normal, or have I got something wrong somewhere ?
I'll attempt the siren exercise tomorrow so as not to wake the nieghbourhood when it goes off...[:I]
Homer
- x 16
