Peugeot Boxer - 2022 - 2.2 - Engine Rattle when cold at idle
bobson6
Unread post by bobson6 »
Hi, Facing a problem with my Peugeot boxer currently where when it is cold there is a rattle, it comes from the top of the engine but seems to come from the whole top of the block. Once the engine is warm there is no rattle/very little rattle. First thoughts were timing chain, but if you read on you will see why with think this is not the case.
My local garage are currently working on it, and they have currently done the following:
Oil and filter change - Genuine parts - The oil that came out was very thick and the last change was 30k before, certainly the worst oil i have seen come out of an engine. (only just bought the van - no rattle when bought) still rattles
Checked oil pressure, in doing so noticed that once the oil pressure switch was disconnected the rattle stops and the engine runs as it should
Replaced switch - rattle continues with new switch fitted
Disconnect the oil pressure regulator solenoid - rattle stops when disconnected, been replaced and still rattles
Now we are down to the oil pump - currently deciding whether to replace it.
Anyone had something similar, I have spoke to a mechanic from another garage who has had a similar issue with a vauxhall where the pump got replaced and the sound went and he feels this is the same.
x 1489
Re: Peugeot Boxer - 2022 - 2.2 - Engine Rattle when cold at idle
Sounds like you have answered your own question, but the only nagging doubt is that the oil pump is doing what it is supposed to, but the command is wrong. Potentially you could scope the signal, but need some reference data to know if it's right or not. Is this the Ford engine? Any hits if you search for similar on Transits?
bobson6
Yeah the euro 6 version, with the short chain between the two cams and then a dry cam belt.
Will try the transit search, i know that there was an oil pump recall on transits around 2015, which would be a very similar engine to this one.
My gut tells me its the pump, just hoping some others may have had something similar.
bobson6
So an update.
Sump off and the pump removed. No sludge or blocked pickup which is what we were expecting. New pumpnis being fitted. Get outcome of this today. Not convinced this will solve the rattle.
Some data, when the switch was taken out and a pressure gage put in its place the pressure was at 6bar which we are guessing is a default for the pump when the switch is not working but the rattle is gone. The pressure on diagnostics with the switch connected was around 1.2bar and it was rattling.
Now after doing a bit of Internet digging I came across a post about a blocked or stuck open pcv or ccv. Would a blocked ccv cause the top end to rattle after start? (Side note - when ibdid the oil change the oil cap had evidence of gunk build up on it to match the sludge coming out the sump) They have also found some evidence of oil leak around the fuel pump which could be due to increased pressure from ccv closed if I'm correct.
PaulC5
x 690
Unread post by PaulC5 »
Low oil pressure or low flow can give a top end rattle. I had this years ago on a Fiat when the oil pump was worn out.
bobson6
Update
New pump fitted. Pressure is running the same as another van in the garage and the rattle is still there. When pressure switch disconnected the pressure jumps to 6 bar and rattle goes. This is the same on good van other than the rattle.
Also when the pressure switch is re connected it takes around 10 seconds for the rattle to re appear.
Any ideas where else to look. Had a suggestion that there could be a blockage in the oil way from the filter to the top of the engine?
PaulC5
x 690
How many miles has it done ? Have you had it checked by a Peugeot dealer to get a professional opinion - if not it might save a lot of money and effort trying things hoping to get it fixed by trial and error ?
bobson6
Peugeot just wanted to hook it up to a computer and not interested in diagnosing the issue. Said no codes it was fine.
Through working with the independent garage I went to we have isolated to the problem to either build up in oil galeries restricting flow to the head or at the extreme end the timing chain.
However when you first turn the key the engine runs fine and only after 5 to 10 seconds the rattle starts and remains until engine oil upto temp.
Readings for oil pressure fall inside demanded figures but this is read at the pump and would not be the figure for the head.
Wheb using a mechanics stethoscope there is alot of noise coming from the vacum pump, not sure this is the cause mind. Then there is no one place where the noise is from. Can be picked up across the whole head.
We still have it when we disconnect the oil pressure switch or the oil pressure regulator the noise stops.
Both these have been replaced along with pump.
BramVan
Unread post by BramVan »
Did you eventually get this fixed then and if so: what was the fix?
Facing the same issue with my 2.2 BlueHDI 140PK boxer engine in my campervan.
Romych
Unread post by Romych »
Hello All ) Thanks a lot for useful information ! I have exactly the same issue with my new Boxer 2024. It has now just 10k km on the odo. Right from the dealership it produces that annoying rattling sound when cold at idle. Revving up to 1200 rom immediately removes the rattle, but it comes back within 10 seconds. When at operating temp the sound is also present but is not loud and overall negligible. The van runs quite Ok. Dealer says what there is no errors so nothing to be done and no reason to raise the guarantee case. Did oil and filter change at 3000 km with no effect. If disconnect the pressure regulator the rattle immediately goes and everything becomes as it should be: no rattle, the engine sounds very smooth. I suspect it can be hydraulic tappets noise: when cold, the regulator valve is open and the oil is thick, both these factors contribute to the effect when one or maybe more tappets is not compensating the lash. When warm, the regulator is closed (to keep warmed oil pressure at appropriate level) and the oil viscosity is also appropriate for normal tappets operations. I am very curious if the solution was finally found for topic starter case ) would appreciate any additional info on it )
Baddeley
Unread post by Baddeley »
Hi, I know this is an old thread, but did anyone get to the bottom of this? I have a late 2017 Boxer 2.0 BlueHdi 130 with a similar problem which I'm currently fixing. It has the top-end rattle that you mention (very similar), but it also has other problems: It blows out a lot of smoke and sometimes goes into limp mode. Also, the brakes have no vacuum assist. Diagnostics says 'injectors programming', which I've done (and was accepted), but has made no difference and the error just comes back. I'm currently removing and cleaning the injectors and have removed the brake vacuum pump, which turned out to have quite a bit of oil in it, so I'm thinking that these two problems may just be partly linked by a PCV/CCV problem, but cannot see how to get this off. The only option I can think of is to remove the valve cover, is this right? Obviously, not a big job, but I've read elsewhere that there's a valve that fits between the head and the block, which needs an engine strip, which I just don't have the time or facilities to do right now. Does anyone have any more info on this? Photos would be very helpful too! Thanks in advance.
[attachment=0]RockerCover.jpg[/attachment]
PaulC5
x 690
If the vacuum pump has a seal between it and the engine block then possibly it is leaking.
Baddeley
Thanks PaulC5, I was also thinking that, but I don't know of any way to test for that - other than to just replace it (which still doesn't prove anything). It obviously uses an oil feed from the engine and maybe the return isn't good, but again, nothing is obvious just looking at it. That's why I was wondering about the PCV/CCV valve leaking into it maybe, possibly also causing my smoking and rattling symptoms? Anyway, I'm going to take the cam cover off and have a look at that and check the cam chain/tensioner at the same time. By the way, I've only recently bought this, so don't know it's history.
Baddeley
Well, lots has been going on recently, mostly related to getting the injectors out (massive pain, but now done, though still need injector 'learning'). It's now running pretty good, but still has the rattle at low revs and still goes into limp mode around 3k revs.
However, I now have 'low oil pressure' and 'oil pressure control' errors. This is again around 3k revs and will be the original cause of it going into limp mode! Oil pressure is Ok below this, but does not rise with revs, as it should. I've ordered a new oil pressure sensor and control solenoid, which should arrive in a few days and will hopefully fix this, but I also decided to check the oil pump inlet for a blockage. There was some muck in there, but not a lot, not enough to cause a problem, especially as pressure is OK below 3k (around 2.4 Bar).
However, the pump chain is very slack!
I can't replace the chain, as it's a full engine out and strip (crank out) job, so that's not happening, and there is no tensioner on these, but I thought maybe a new pump and sprocket might take up a tiny bit of the slack. With 200k on the clock, a new pump would probably not go amiss anway. The trouble is, I can't get the pump off!
I've taken out the two fixing bolts and the pick-up tube, but although it will move up and down at the back and I can easily take the chain off (see photo), it is very stuck on the front edge! I've tried prising and tapping fairly hard with a mallet (away from the oil union), but it just won't shift! It seems like it's stuck at the oil outlet to the crank, but online photos show this to be a flat connection (pump side anyway). Is this just naturally very tight, is there a joint/seal that has to be prised off, as I suspect, or do I need to take care or do/remove something else?
How does this pump come off? Is it usually easy, or do I just need to apply more pressure? I know bobson6 has taken his off, but he doesn't seem to be on here any more. Can anyone else help, is there something I've missed, or am I just not using enough force - I don't want to risk damaging something!
This is a 2017 2.0 BlueHdi, very different to the 2.2, for which there is a ton of information online. I just can't find anything on this for my engine (DW10FUD). Thanks guys.....
