Abs fault code
Stuwoody309
New User
Abs fault code
Unread post by Stuwoody309 »
Good evening all. I am after a bit of advice if possible, or pointing to the correct topic if I am duplicating…
Anyway, I have a Renault grand scenic 2 2008 and it’s playing hard ball… I bought it to ship my family around when they come over in the summer then it’s off for sale again!
Anyway… I’m down to the last two problems before mot time
The window washers don’t work. I assume it’s the washer motor as there is no sound coming from down there.
The big issue I have is the abs. I have a fault code of P2F0D and it tells me to refer to the service manual. I’m using the Autel fr705 scanner and I can do live data which shows the front wheels responding to me turning them.
Both back wheels do not show any data when I spin the wheels but only one fault code is showing and it returns after I reset and drive for 100 yards.
When I unplug the sensors, I get two different codes which show the description of the left or right sensor unplugged, so I assume the module is working fine.
If both sensors are faulty, I assume it would throw 2 codes up?
Thanks in advance!
Stu.
