Now you can insert the USB stick into the USB port of your RT6 unit???
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
ChrisKe
x 4
Unread post by ChrisKe »
Been plucking up the courage for a year to try the mirascripts repair for my SD card but every single line seems counter intuitive so I have to wonder whether it's even referring to my RT6 unit? I have seen units with SD card slot at the front. Mine is inside
Im now at this line:
....Now you can insert the USB stick into the USB port of your RT6 unit....
My RT6 doesn't have a USB socket, just micro SD card???? Just plain scary
x 6957
Re: Now you can insert the USB stick into the USB port of your RT6 unit???
All vehicles with an RT6 have a USB port on the vehicle.
If you have an SD card slot on the front of the Head Unit, then you don't have an RT6, you have a MyWay system.
Look closely at the pictures in the main index of the telematics Forum here:
viewforum.php?f=44
Although they look the same they are not - on the MyWay system at the centre bottom of the head unit you can see the word SD with the slot.
The RT6 doesn't have an SD card slot there.
