Hello,
Today, when D gear is placed, there's "bump" . When driving, everything works perfectly.
Citroen c5 2012 150kw .
What can cause this problem?
Bump on D gear, 150kw
citroenguy
- (Donor 2021)
- x 77
Re: Bump on D gear, 150kw
If you are really lucky, flushing the gearbox might help.
Otherwise the gearbox needs to be taken apart and change some seals.
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
Karolis Vansevicius
But this happens not always .... strange
Karolis Vansevicius
I think I'm the lucky one.
After changing the oil (full change), the problem has gone and when you switch the Gear D - you can't even notice anything
