colant fan not starteing Peugeot 307sw
Ryssen
Unread post by Ryssen »
When the engine gets hot up to 95 to 98 degrees celcius the cooland fan does not start.
where is this on the engine https://www.autodoc.se/metzger/1811851
Any one have a sceets or a picture of where its located on the engine ?
x 1044
Re: colant fan not starteing Peugeot 307sw
Unread post by wheeler »
dont throw parts at the car without getting it checked first. Coolant temperature sensors do fail but when they do they normally cause the fans to run all the time, the system defaults to safe.
A simple OBD diagnostic tool should be able to read the live data of this sensor & you can see if it is reading correctly.
Ryssen
Ok I will get it checked with OBD.
