Hello.
I can't get rid of the P3027 Flowmeter signal Air flow too low fault in my Citroen C5 X7 RHR 2.0 HDI Sedan from 2009. The problem is occuring since I bought the car.
I replaced all filters, the air sensor (to NTY ECT-CT-000), I cleaned my air intake.
If I clear the faults, the P3027 fault appears again right after ignition. Always. I haven't noticed any symptoms personally, but I haven't driven any other car of my model.
What may be a reason for the fault?
toolfan
- x 3
Re: P3027 Flowmeter signal Air flow too low
Some aftermarket sensors fail right out of the box. I would try to get an "expensive" one from another brand to confirm or not.
- x 5582
Seimens/VDO are the reliable and OEM ones (VDO a Siemens spinoff company)
steveclv
- x 40
I have had something similar with other cars - cleaning the element of the MAF (Mass Airflow Sensor) has worked - use brake cleaner and never touch the wire. But failing that then a quality replacement sounds like the next thing to try.
- x 1044
Have you looked at live data from the flowmeter? what does it read at idle?
To confirm are you saying that after you clear the fault & switch just the ignition on (without starting the engine) the fault code comes straight back? or does the fault only come back once the engine has been running?
cit-rotti
- x 78
There are special air mass sensor cleaners, e.g. from Liqui Moly No.4066. All other cleaners are suboptimal.
Please check the multi-pole wiring harness - such faults are often caused by defective cables or connections - the power connection in particular is suspect.
A suitable wiring diagram would be helpful.
Greetings Wolfgang
Greetings Wolfgang
