I have posted about this issue previously as it was intermittent. Now I have a permanent error come up that is a tyre pressure monitoring fault. The display show all 4 tyres.
I read the code and it's C1604(95) under TPMS. Any ideas anyone?
TIA
TPMS issue
- x 6955
Re: TPMS issue
For all tyres to lose detection it's either the TPMS ECU, the wiring connections, the sensors (unlikely if all 4 have gone together) or the programming of the sensors has been lost and lastly, I think I mentioned before that all need re-programming, even if only one has gone, as it can affect the others.
- x 6955
Re: TPMS issue
Well they may be able to check the ECU or at least try re-pairing the sensors to the ECU and see if that fixes it, but you will have at least got a proper check.
