ABS module connection plug
Cynthia13
Unread post by Cynthia13 »
Further to our ABS/ESP warnings issue, brake light switch replaced but to no avail. Next will be the engine speed sensor but in the meantime thought to undertake a BSI reset (guided by the helpful post on the FCF).
Whilst battery disconnected thought to give the ABS module electrical connection a clean and check for damp. The module is visible under the main fusebox but not sure if the plug is a pull to extract/push to replace, or if there are fittings which can't be seen from above on an initial cursory look. Any pointers?
Usual thanks and congratulations on an excellent site.
