Last time I posted about a noise coming from the drivers side of the engine. You said possible upper engine mount . You where correct. So replaced same. The noise went away and has stayed away. However at times when I start the car up there seems to be s slght bang when starting then it drives ok. It seems now to be coming from the passenger side of the engine. Could this mean another mounting ??.These noises are doing my head in. Also sometines the car would pull slightly to the left AT TIMES if you are testing it for tracking.It couldn't have anything to do with the engine moving when driving could it
Sorry about this.
Regards
Roy
