only done 49000 can anyone help please
ECU problems
Paulc5060
ECU problems
So I've been to Citroen today to check on my picasso C4 65 plate 1.6 diesel . Not looking good ECU locked and will not start. Waiting for Citroen head office to look into it ? If it's no good can I fit a second hand ECU kit . Can someone tell me what I would need to change over also if I go that way what happens to my mileage . As my car has
- x 6950
Re: ECU problems
Has you taken the vehicle to anyone else / another garage just before this happened? If somebody has mucked about with the engine ECU they may well have mis-configured it.
Normally this happens when the fobs are not initialised after a car battery change of the batteries in the fobs and can be reinitialised following the relevant part after the BSI Reset / Battery Disconnect / Reconnect Procedure.
You can't just replace the fobs if the engine ECU is faulty, it will need a new engine ECU or a virginised one, then it will need programming online via a dealer (can be done if you have a PSA account , the diagnostic equipment and pay for access) and then it will need to be paired with the BSI and the vehicle fobs.
Hopefully it won't come to that.
Has the wiring or anything been done near the engine fuseboxes, or any equipment added to the wiring?
