Lexia communication module for c5x7.
obolikol
Unread post by obolikol »
Hi i have a question, will s1279 lexia module connect with my c5 x7 or do i need some other module for thus car?
x 6950
Re: Lexia communication module for c5x7.
You do not require this module - it is only for 'commercial' designated vehicles like the Expert, Boxer and the Ford / FIAT variants like the Nemo as examples. The X7 does not require this.
obolikol
GiveMeABreak wrote: 23 Apr 2024, 10:14 You do not require this module - it is only for 'commercial' designated vehicles like the Expert, Boxer and the Ford / FIAT variants like the Nemo as examples. The X7 does not require this.
So only obd2 to usb or com and software?
x 6950
S1279 module is for use with a Lexia 3 VCI kit with Diagbox for commercial vehicles.
So a Lexia Kit will have VCI interface connected to OBDII port and your laptop and yes, you need Diagbox software.
I can't comment on other after-market diagnostic kits and their requirements.
x 1955
Unread post by Paul-R »
What is more important is to know whether your VCI (the hardware that plugs into the OBD socket) is full chip and has Rev C chip firmware. Also, what software are you using? Lexia is probably too old even for a 2009 X7 and you need Diagbox. What version of Diagbox are you running?
Zokom
Unread post by Zokom »
Hi, I am too searching a Lexia 3 module for my 2010 C5 X7 but I'm based in Italy, do you have by chance any european shop with some good options? Also I'm quite a noob in this but I know I would need a PC with winXP installed to run the machine for the diagbox, anything else? Thanks
