Constant regeneration
Ted
Unread post by Ted »
Hello all, I am after some help from you knowledgeable folks. I have a 2019 citroen relay 3, it has 64000 miles on clock and is constantly trying to regenerate the dpf, citroen have had the van for weeks and can't get anywhere with it, I have had the van plugged in and all data shows the dpf to be fine with no high back pressure. I'm at a loss and use the van for my living it has fixed equipment in the back so can't even use a hire van, thanks ted
x 1485
Re: Constant regeneration
Shooting in the dark without any data.... But is the outside temperature indication working?
Ted
Hi yes all working ok, vin number is VF7**************[VIN obfuscated, can be read by forum staff], what is eolys fluid and how will I know if van has this?
x 6956
Yes, you have a particle filter and a reservoir system that requires Powerflex additive.
Ted
What eolys fluid will I need?, where best to get it from, I'm going to check fluid tomorrow fingers crossed its as simple as low fluid, good start point at least
dougie1142
Unread post by dougie1142 »
Hey, long shot but did you get anywhere with this? I have the same year van, once it goes into regen it never stops. I have no warning lights on the dash, the differential pressure looks perfect, Eolys level is fine and adblue fine. Only way I can get the regen to stop is by forcing a regen using Diagnox then it stops for 1500-2000km.
Cheers!
