DS3 front hub
dylan26__
x 22
DS3 front hub
Unread post by dylan26__ »
What's is the socket size and torque for the front hub nut? Need to get it out but it seems huge for the size of the car. Measured it seems 35 or 36mm but want to be sure
x 8172
Re: DS3 front hub
I'm pretty sure that is a 35mm nut and the torque will be 110 NM :)
dylan26__
x 22
Re: DS3 front hub
mickthemaverick wrote: 20 Apr 2024, 08:07 I'm pretty sure that is a 35mm nut and the torque will be 110 NM :)
Thank you :) of course it has to be a rare size socket 😂😂
x 8172
Re: DS3 front hub
Sorry Dylan I put the wheel nut torque there not the hub nut which I believe is 320 NM !! #-o
x 1955
Re: DS3 front hub
Unread post by Paul-R »
It's FT in the vernacular. I use a long breaker bar with a 5 foot length of gas pipe slid over to loosen it off.
x 1504
Re: DS3 front hub
35mm, PSA have been using it for years. A 36mm six sided usually works. Yes, torque is 240 lb ft - it's not as tight as you think, that's only my 200 lb standing on 14" of breaker bar.
