Gearbox oil info for citroen c3 II 2012 1.6 diesel
zantoniosalas95
Unread post by zantoniosalas95 »
I want to know about the quantity of oil for a manual gearbox oil in this VIN VF7**************[VIN obfuscated, can be read by forum staff]
x 6950
Re: Gearbox oil info for citroen c3 II 2012 1.6 diesel
It depends on the operation - you should measure the oil removed and top up with the same amount.
For a drain and refill the quantity is less than a complete overahaul:
It is necessary to drain the gearbox and put back the exact quantity of oil, in the event of an external leak or a repair.
Gearbox empty: 1,9 litre.
After draining: 1,8 litre.
zantoniosalas95
Thank you do you recommend the additive of Molybdenum?
