Front wipers are not working in C4
kienalance
Unread post by kienalance »
hey, apologies upfront if this is wrong place or method to ask about this.
I've bought a 2009 Citroen C4 1.6 as a second car but with a quirk, its front wipers are not working -so its tad risky to drive it in rainy days =) Rear one works well and I've checked the fuses, so it is not that. What part should I check or change, if I can ? If anybody can help, my VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Thanks !
x 1504
Re: Front wipers are not working in C4
These are effectively computer controlled, so you'll need to get it on a computer to see if the messages are coming from the switches, if the BSI is interpreting them, and if the motor(s) are working.
kienalance
Is this something i'd see in OBD ? I could not find an error code related to it, if I take it to mechanic, probably they will ask everything to be changed, I just would like to have bit more info beforehand.
x 1504
Not necessarily OBD, you would need a decent diag tool that can read the live data from the BSI.
