C4 grand picasso front abs screws
wirralalan
Can anybody tell me what size replacement torx screw I need for the front abs sensor on a C4 Grand Picasso 2007
- x 1504
Re: C4 grand picasso front abs screws
M6 x 1mm thread x 16mm - when I broke one on mine I just drilled it out and then put an M6 bolt in with a nut behind the disc (I had the hub out doing a wheel bearing, so it was easy to get to!)
wirralalan
That's great thank you I may give that a try
