Citroen C2 VTS Cruise Control
Bigbilly
Unread post by Bigbilly »
Hi all,
I’ve just bought a 2008 C2 VTS Code, a great little car that’s better than I expected. Accordingly, I’m happy to use it on longer runs rather than just locally & I’m wondering if I can easily retrofit cruise control by installing a column stalk to the left of the steering wheel. I know some earlier cars were fitted with steering wheel mounted c/c buttons (and I’ve read the VTR post on retrofitting c/c to a Sensodrive car in Aus) but the handbook shows instructions for a stalk mounted option on the VTS, as fitted to other Citroens of the same era. Does anyone know if I can simply retrofit a plug in stalk (the column cowling would need cutting) and if the relevant pedal switches are present (I can see a switch on the brake pedal)? If it is possible I also assume it would need to be configured with Lexia.
Thanks in anticipation.
Bigbilly
Re: Citroen C2 VTS Cruise Control
Hello,
Did you ever find an answer to this? I’m in the same position with C2 Code based on the VTS 1.6 and would like to retrofit cruise control if possible.
