Swapping RNEG for Android Auto
This section is for information and posts relating to Audio Head Units, and Navigation Systems
DustyBAT
Unread post by DustyBAT »
Hi all
New to the forum 👋
I have a 2010 Pug 3008 currently with the RNEG/My way sat nav unit installed. Looking to replace this with an Atoto A6PF double din unit I have. However having issues finding which ISO harness I need to power it up. I have took a punt on a couple and they don't work.
Any ideas which cables I need? I understand it will probably need to have a canbus decoder with it. Would like to retain SWC and parking sensors ideally.
Many thanks in advance 👍
x 6957
Re: Swapping RNEG for Android Auto
What features you can retain (if any) will be dependent on the capabilities and compatibility of the after-market unit you are intending to fit, as the telematic Head Units are very much integrated into the vehicle. I can't help you with this, sorry, and I suspect you will need to contact the supplier of the replacement unit for support.
