Citroen Hy Van
Simonh158
Citroen Hy Van
Unread post by Simonh158 »
Hi I was wondering if anyone can help.
I recently bought this van, I am struggling to determine its year, I have searched various websites but can’t work it out from the reg.
I am also struggling to remove the wheel hub unsure hot to remove the cap or castle nut.
Any help would be greatly appreciated.
Many thanks
Simon
x 1481
Re: Citroen Hy Van
Unread post by xantia_v6 »
The last paragraph on https://cats-citroen.com/citroen/organu ... 20firewall. may give a clue on finding the build date.
Simonh158
Re: Citroen Hy Van
Many thanks I will take a look
moizeau
x 423
Re: Citroen Hy Van
Unread post by moizeau »
French registrations bear no connection with manufacture date, simply when it changed owners or moved departments. This is especially the case with the old style registrations like yours. The 36 on yours means that if was last registered in Dept. 36. The Indre, strangely enough it is where I live. If you have the Carte Grise (logbook) it will tell you on there.
Pete
