Replacing the Main/High Beam bulb on a C3 Aircross
hastings-c4grand
Unread post by hastings-c4grand »
Hi Community
Do you happen to know if there is a guide for replacing the Main/High Beam bulb on a C3 Aircross 1.2 PureTech ( 110ps ) S&S SUV 2019MY?
I can reach the rear of the unit holding the bulb but am unsure how to disconnect and withdraw that unit from the housing.
Many Thanks
x 1504
Re: Replacing the Main/High Beam bulb on a C3 Aircross
It should tell you in the handbook - usually either a spring clip or a rotation required.
hastings-c4grand
Thanks Richard. I'll take a look. Should have occurred to me to do so.
x 1955
Unread post by Paul-R »
I find it easier to take the headlamps out on our 308 and change the bulbs on the kitchen table than struggle to do them in-situ. Maybe the same for you?
hastings-c4grand
That sounds like an interesting alternative. I hate changing bulbs. I guess I should I pick up a Haynes manual to see how to remove the headlamp?
x 1504
On most modern cars it is a bumper off job....
hastings-c4grand
Err...blimey.
x 1955
I did say 'maybe'. For me it's a matter of two screws and disconnecting the wiring plug. Then easing the headlamp unit out. Thirty seconds at most.
