Hello,
I wanted to replace the rear wiper arm of my Citroen C1 Mk2.
It is very rusty. I managed to remove the nut after using WD-40, but now I can't pull the arm at all. It's not budging.
The bolt is also rusty and stuck in place.
I don't want to apply too much force to not break anything.
I've used WD-40 twice already on the area but still, nothing. I even tried to tap a bit on the bolt with the metal handle but didn't do anything
I am not sure though - is it really because of the rust - or something else in this design?
What can I do?
Can't remove rear wiper arm - any advice?
- x 5688
Re: Can't remove rear wiper arm - any advice?
A proper penetrating oil would be better than WD40 and WD40 make one. The usual go-to one is Plus Gas though.
Also, phosphoric acid will help to remove rust, and works better mixed with ethanol.
Both can be had from Amazon as well as other sources.
40% phosphoric acid, 40% water, 20% ethanol.
There are also some OTC rust removers mostly based on phosphoric acid.
Amazon that are probably more economical for your purposes.
A three legged puller may also be useful but a fair outlay for a single use. you may be able to borrow one though.
- x 1061
Its a plastic wiper arm, all a puller will likely do is break the plastic bit off & leave the metal sleeve stuck on the spindle. With the mk1 C5's with a similar design i never used to waste any time trying to get them off after they had been on there a few years, just break the plastic off & dremmel the metal sleeve off & fit a new arm.
Lenny
- x 63
- x 1061
You can certainly try it but in my experience all they do is rip the plastic arm off & leave the metal bit still stuck on the motor shaft which needs to be cut off.
Its less than £14 for a new arm complete with blade
I would concur with what has already been said in my experience, a bit of careful surgical destruction, and a new arm may be required. Your puller may work, that's what they are designed to do, but when corrosion perversely appears to weld components together removal even with the puller may be difficult.Lecit wrote: 06 Apr 2024, 14:45 I wanted to replace the rear wiper arm of my Citroen C1 Mk2.
What can I do?
Bit of a re-edit after realising its the rear wiper arm you are dealing with, which carries the jeopardy of the wiper motor shaft splines and threaded end poking through a hole in the rear window. Leverage against the glass not recommended.
This vid shows a similar difficult job on a C1 rear wiper. Eventual success, not that keen on his "boiling water" intervention. As ever no recommendation, make your own mind up and good luck.
NeilLink to vid
https://youtu.be/GmLzNUuDp_I
Lecit
Thanks everyone, sorry for the late reply! I still haven't done it yet, but will try using your tips now
