Hi I have a 2010 dispatch combi that got flood damaged 2 bent rods ets so I don't mind rebuilding it but will be a lot quicker and cheaper to put a replacement in
Problem is it has a 120 hp RHK DW10UTED4 engine in and finding an engine with less than a million miles on it or need to remortgage is impossible but there are loads of picasso RHJ DW10UTED4 ONES OUT THERE CHEAP AND SOME RHR
Dose any expert know if these will fit I will keep my injectors in
2010 dispatch engine swap help
richardwarry
Re: 2010 dispatch engine swap help
Right update I brought 2010 RHR engine from a low mileage 407 56k 130hp with Delphi injection my RHK 120hp had Bosch so changed the turbo,injectors,pump all fitted easy took the sump off and pick up pipe was the same only other thing that was slightly different was through oil filler tube slightly different angle so I left it
Fitted new belts etc and she runs a treat and at £400 from a breaker it's a lot cheaper than a dispatch one
