Hi there, does anyone know which diagbox version is required for the C5 Aircross?
Thanks!
Diagbox version for C5 Aircross?
cit-rotti
- x 78
Re: Diagbox version for C5 Aircross?
If you want to do it yourself, you should preferably use a DIAGBOX 9.xxx - ideally from update 9.150- 9.180 (for vehicles from 2014), which can be installed both as a VM or natively on WIN10/WIN11 64 Bit Pro. If a suitable laptop is available, then only VCI + software + installation is required - costs between 100-120€ for self-installers with a China clone or currently 160€ with a used original VCI.
This allows all the usual offline diagnostic work to be carried out - only if offline changes are made that involve changes to control unit software will an access code from the chargeable hotline be required, because newer control units from 2015/2016 onwards do not enable offline access without this code.
Greetings Wolfgang
Greetings Wolfgang
zakazak
- x 4
Thanks a lot.cit-rotti wrote: 04 Apr 2024, 10:24 If you want to do it yourself, you should preferably use a DIAGBOX 9.xxx - ideally from update 9.150- 9.180 (for vehicles from 2014), which can be installed both as a VM or natively on WIN10/WIN11 64 Bit Pro. If a suitable laptop is available, then only VCI + software + installation is required - costs between 100-120€ for self-installers with a China clone or currently 160€ with a used original VCI.
Greetings Wolfgang
I got diagbox 9.xx installed and also got a Lexia device (Lexia-3 xs evolution supporté V48 PP2000 V25).
Is there also any way to check the service intervals / what has to be done for each service and also check workshop manuals offline (e.g. without being connected to the car)?
I couldn't find that in diagbox yet but found a website that seems to offer it (www.haynes.com).
Thanks!
cit-rotti
- x 78
Current access to spare parts, repair instructions, circuit diagrams etc. is not possible with offline diagnostics.
However, PSA offers everyone the opportunity to take part in the online service for a fee. This requires a corresponding account with PSA and, depending on requirements, corresponding parts can be used/purchased permanently or for a limited time.
Not exactly cheap fun. An original VCI should also be used - although many report that the clone usually works too.
Any offline diagnostic software installed is completely unsuitable for this - activation is the cheat and there are also occasional slips in the software.
For vehicles up to approx. 2013/2014, there are repair instructions/schematics for both Citroen and Peugeot which can be installed and activated on a PC/LAPTOP (DocBackUp and SEDREBackUp). After that, everything was only available "online" for a fee.
Address for free software from DIAGBOX and repair instructions:
https://guiapsa.foroactivo.com/login
And of the current DIAGBOX software:
https://www.psa-diag.fr/forum/index.php
Greetings Wolfgang
Translated with DeepL.com (free version)
Greetings Wolfgang
zakazak
- x 4
cit-rotti wrote: 07 May 2024, 11:24 Current access to spare parts, repair instructions, circuit diagrams etc. is not possible with offline diagnostics.
Greetings Wolfgang
Thank you for the link to foroactivo... I tried registering for the servicebox but I am not sure if I did everything correct since I do not speak spanish and half of the images included in the guide are not existing anymore.
I can log into the servicebox but I can still not access the information for free.
- x 6956
It is NOT free, you have to pay for it.
