Carplay Activation
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
Hadenbury
Carplay Activation
Unread post by Hadenbury »
Hi, I have a 2016 C4 Confort Techno Plus. (1.6 BlueHdi version) I heard its Carplay could be activated. I researched everywhere and I couldn't find a solution. The authorized services told me they can not activate Carplay. How can I activate it? Could it be activated by a software update? I downloaded Citroen Update app to my Windows laptop and I got "CITROËN UPDATE does not allow the update for this vehicle. We recommend you to access to the website of the brand." warning.
x 6957
Re: Carplay Activation
You can't simply activate what is not there!
It depends on what system you have and whether CarPlay is supported or not.
I will first need your VIN to see exactly what vehicle you have and which options and equipment to be able to assist. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Hadenbury
Here is my VIN:
x 6957
Ok, so you have a vehicle with a SMEG Head unit, not the later RCC or the NAC units.
Your specs say without Mirrorlink, which was the pre-cursor to Android Auto and for which support has been pretty much discontinued by phone manufacturers and there is no WiFi on board either.
Some units could have a firmware update applied, but they had to be the later models I believe SMEG+ IV2. I can't tell though if your unit is this model as it's a basic model. If you hold down the SOURCE button, it should provide the software version and other info - if you could take a screenshot of that and upload it here using the full post editor option and attachments tab, I may have a better idea of which system you have and whether it can be upgraded or not.
If you have the older earlier SMEG system, then it can't be updated to support CarPlay / Android Auto. In this case you would need to get a later Head Unit, have it coded in etc.
Hadenbury
Hi, sorry for delayed answer. I checked version of SMEG. It is SMEG6.1.D.R19 (I couldn't add screenshot) I think this means it is SMEG+ IV2
Hadenbury
Hi, I researched my SMEG version. I saw it has Carplay but it needs a firmware update. When SMEG updated to latest versions, Carplay and Mirrorlink buttons coming to instead of Internet button. But I read Carplay need to activated by "Diagbox" after update.
What we can do right now? Can I do these steps by myself?
Thank you for helps.
x 6957
Hi
You won't be able to do this yourself unless you have Diagbox V9.**, the laptop and Lexia 3 interface VCI etc. and pay PSA for diagnostic token.
Therefore it would be easier and probably cheaper to ask your dealership to update the firmware and activate CarPlay for you.
Hadenbury
Thanks for help
Hadenbury
Hi again. I would ask can I find the firmware and update it myself? I contacted my dealership and they said they are unable to update but if it could be updated they can activate carplay.
I researched and I didn't find the latest firmware. Could you provide me the latest firmware for my car?
x 6957
Sorry, I don't have it.
XUD9
x 6
Unread post by XUD9 »
Hadenbury wrote: 04 Apr 2024, 08:36 It is SMEG6.1.D.R19 (I couldn't add screenshot) I think this means it is SMEG+ IV2
SMEG 6.1.* and above supports CarPlay. No need to update the firmware. All you have to do is to activate the CarPlay option.
There are three ways to do it at home:
- via WiFi (if the unit has) . Easiest way.
- via Bluetooth (harder) ;
- via UART port. Requires disassembly of the unit, soldering + additional equipment;
P.S. : If for some reason you are planning to update the firmware, use versions up to 6.1.D.R20 (including) !!! The new ones don't have the WiFi option (it will just disappear) + some other features. It's impossible to downgrade.
P.S. 2 : Old discussion, but the info might be useful to someone...
nate
Unread post by nate »
XUD9 wrote: 14 Sep 2024, 00:02
How can one proceed to activate CarPlay through Wifi ? I'm on 6.1.D.R20 but without CarPlay.
Sapricot
New User
Unread post by Sapricot »
Here is a very thorough guide on how to manually activate Carplay on Smeg 6.1.D.R20 (might work on other versions too). I just followed it and got my Carplay working.
Since my car already had wifi activated, I connected the car to my iPhone's hotspot and used iSH to connect through telnet. I first had to update packages in iSH and install telnet with apk add busybox-extras.
https://www.gpspower.net/peugeot-citroe ... ost1231067
Hadenbury
Sapricot wrote: 12 Dec 2024, 22:42 Here is a very thorough guide on how to manually activate Carplay on Smeg 6.1.D.R20 (might work on other versions too). I just followed it and got my Carplay working.
Hi there! I know it’s been a while since you posted this (I just saw it after a year!), but I’m currently trying to activate CarPlay on my SMEG 6.1.D.R19
I've managed to set up iSH and telnet on my phone, but unfortunately, the GPSPower link you shared is no longer accessible for me. Could you please provide more details on what to do once I'm connected via Telnet? Which files did you modify and what were the specific commands to enable the CarPlay option?
Any help would be greatly appreciated. Thanks in advance
