I have a 2021 DS7 Crossback Louvre. The n/s rear light had water in it and I reported it, double figure emails and phone calls later it has failed and now does not work.
I can’t tell you how bad the customer service has been and the dealership are downright rude and obnoxious. I have now been a week without a car with no end in sight.
Apparently there is a 3 month waiting list for the part 9824986580. Dies anyone know where I can get a cheap quick replacement just until DS get their act together?
Ds7 Crossback N/s rear light replacement
- x 6960
Re: Ds7 Crossback N/s rear light replacement
Hi
Unfortunately not unless you opt to go for a second hand replacement - but I'd advise against this as if you do that they may not cover it under warranty, as they use various checks and tests to determine the water level in any ingress to lights before determining whether a replacement is warranted. If you go ahead and intervene they can refuse to do the work on the basis you have undertaken repairs yourself and won't touch it. Further, considering these are £462
each, I'd be inclined to let them sort it under warranty!
Assuming your car is under warranty and the lights are not cheap, I'd hang on and let them sort it. As long as you have evidence you have reported to the garage and they are dealing with it, you should be covered legally.
Clarkeeee
Mark, I couldn’t wait as I would have been months without the use of my car! Still have no appointments to fit it and insist on 5h fitting time (which can be done in under 10 mins) on top of a 4h round trip without a working light… or recovery.
- x 6960
That's atrocious! Can't believe that delay.
